- Apr 27, 2013
right now this 7970 is the hottest component on my rig, after push/pulling hyper212 evo with 2 cougars, the noisy assistant fans inside Z87 Sabertoogh's TUF to deal with MB, my highest temp's for this 7970, it usually hit 70 at most when im playing for hours, and it shorten its lifespan im sure.
its Evo's stock fan in there
I've three questions:
(1) does any Intel GPUs like 680 or 780 get hot like this?
(2) whats ur opinion about another option and put the fan below GPU and replace the GPU for the upper PCIe3 slot, or the current one is effective?
(3) GPU-z says the GPU is on PCIe v3 x8 while it supports x16,
the Manual says: 2x PCIe 3.0/2.0 x16 slots (single at x16 dual at x8/x8 mode)
I use only one GPU so why's its showing x8 mode
thanks in advance for helpful tips
