- Feb 18, 2002
I have three 256MB PNY PC2700 (Bravo chips) RAM sticks
I used 3DMark05 to tested them like so to find that
1.)
1 stick in slots 1&3 (for dual channel, with slot 2 empty)
vs.
1 stick in slots 1&2 (supposedly single channel even though Cpu-Z still reported dual(?), with slot 3 empty)
shows less than 3% difference in 3DMark05 score.
2.) All three slots filled for 768 MB of RAM instead of 512MB of RAM show a 9% score decrease (!)
3.) I tested two sticks in slots 1&3 (dual channel) at
6 3 3 2
6 3 3 2.5
6 3 3 3
only to find less than 1% difference in 3DMark05 scores.
I used 3DMark because I though I would see how these things affect playing games.
What do you think about the differences as mentioned above in terms of how they would affect things if I used different testing methods?
What is your answer when asked: should I go for extra xx FSB or tighten the CAS Latency from
6 3 3 3
to
6 3 3 2.5 or 6 3 3 2
_________________________
AMD Athlon XP 2400+ mobile 35 watt AXMD 2400 FJQ4C
IQYHA 0402 SPMW
[192] FSB x 12.5 = 2400 MHz @ 1.85 Vcore with memory frequency at 100% [192 FSB] @ 2.90 Vdimm
Epox 8RDA+ v1.1
Thermalright SLK-947U with variable speed 80x25mm Thermaltake Smart Fan 2
AIW 9600XT 128MB; Antec SX-835II case ; 380W Antec TruePower TP380
Four 80x25mm Case Fans + 1 Variable speed 80x25mm Fan YS-Tech FD1281259B
1.)
vs.
6 3 3 2
6 3 3 2.5
6 3 3 3
6 3 3 3
to
IQYHA 0402 SPMW
Epox 8RDA+ v1.1
