Trying to build a computer with some of the latest technology. The computer I use now is my Asus g60 laptop which is dual core 2.13 with 4gb ram and Nvidia 280. So now I am looking to build a desktop and spend no more then 1k on the tower. Here is what I came up with so far. I plan to be playing some SC2, BF3, D3. Nothing to serious. Suggestions or opinions would be appreciated. Thanks!
GIGABYTE GA-Z68XP-UD3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
EVGA 01G-P3-1373-AR GeForce GTX 460 (Fermi) Superclocked EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ...
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power ...
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Thank you all!
EDIT: I have changed the MOBO, HD, CASE, RAM... Working on a new GPU atm and other suggestions appreciated. Thank you all!
Thank you all!
