HotHardware mentioned that the 920 and the 870 (or the 860 forgot which one) are the same processors. It's just one runs on tri channel memory, one runs on dual. One runs on X58, one runs on P55.
I think there will definitely be more processors for the 1156 socket. Just not now.
the funny part about reading most of the reviews. is that they dont bench the i7 860 but only the 870. now the problem i see is that clock to clock with ht there is no comparsion. since i only have seen i7 920's used, noting close to the clock of the 870. some will think i7 1156 is faster since it is a higher clocked one vs the i7 920. when in fact it isnt clock to clock faster, lga1156 uses the DMI buss vs QPI on 1366. the DMI buss is a good thing in a way but is slower then QPI.
*edit*
should be to compare clock to clock, down clock or drop the multi on the i7 870 for i7 920 speeds. lost track the 860 isnt clocked at 2.66ghz but would have been nice to have a 850 in the line up then....
maybe the dies are but the LGA11566 cpus is the same size physical size as LGA775 cpus.
The BEST reviews are done CLOCK for CLOCK. I like to see when they take 4-5 CPU, clocked at "3.2ghz" and lets see how they perform. Cause in these review, the closest PROC to what i have is the Q9550s but he is running 2.83ghz .... or the QX @ 3.2 that is closest to me.
I have this rig for 6month now. Im about to swap to new gear since i feel outdated but the performance gain isnt going to be what im looking for. Ill kee this Q9550 till i see someting rweally better for my use ( mainly gaming/webbing )
that may not be pushed as much as you think... since NV demo'd real time AI of flying planes or something. they listed some ungodly amount of planes that could be handled via gpu vs cpu. the cpu could only handle, if i recall right, 400 planes. NV gpu has something like 1000+ planes at once...Based on what I have seem, I really don't see a reason for i5. I would go with i7 8xx with HT enabled or i7 920. The price delta is too small. HT is definitely worth the price. You can see significant improvement in video encoding specifications. I suspect in the future as games start to use more CPU for physics/AI, you will see more boost from HT.
Personally, I like i7 920 better than i7 8xx.
*edit*
