My much hotter 3930k stays under 63C at full load with a cheap 212 Evo. The fact that a 240mm watercooler on a 2700k gets around the same full load temp means the watercooler is junk or (more likely) there is some error in the install or bad airflow. (Try cleaning the coil with a bicycle pump if you have been using it for over a year.)
