Hi there,
I know there have been some threads concerning this mobo and CPU on the internet, but none meets my question a hundred percent. So:
I have an ASUS B85M-G with an I3 4330 and ASUS GTX750ti (will be upgraded soon) as well as 2x Crucial Vengeance 4GB RAM DDR3, 1600Mhz. I know MoBo-Processor-Combination is not the best at all, but a friend of mine gave me his I7 4790k for a few bucks and I know it's compatible. I updated the BIOS to Version 2501 (or something), which is the latest Version from 2015 and brings compatibility to devil's canyon. If I try to boot, there is no "beep" and no boot with the i7. If I change back to the i3 everything works fine. What could be the problem? Is 350 watts ATX to "powerless" (4pin-plug)? Can an ATX with more power (be quiet 550w) give more power to CPU through the 4pin-plug or is the plug limited? I have a really bad and low-budget ATX but want to upgrade to be quiet 550w.
The processor is optically fine and has worked before in my friends PC.
What else can I try? Could there be a problem with RAM-Banks/Slots? I have read something about problems with RAM... In BIOS it shows 1333Mhz, but the Crucial should run on 1600. It is a 1.5V Bank. Could there possibly be a power-problem?
Even without GPU there is no boot.
Would be great if someone has an idea. Thanks a lot. If you need more information, just ask.
Regards,
Peter
Regards,
Peter
