Hey,
I've recently did a RAM upgrade from 6GB of patriot DDR3 1600mhz to 12GB of Corsair Dominator 1600mhz. For some reason, after the upgrade my CPU temps were insanely high, reaching about 94 degrees at max load. I thought it was the RAM but the temperatures were still the same after i switched back to my original RAM. My max load temp before was around 69 degrees. I'm currently using a Corsair H60 liquid cooler.
Things I've tried: Repositioning the cooler and reapplying thermal paste (tried this 2 times).
Remount the bracket and get rid of everything that is in contact with the CPU.
I didn't really move anything yet the temperatures just suddenly went berserk. I'm not sure if the pump is broken but the fan seems to be running fine. How can I tell if the pump is broken or not?
Any possible solutions is welcomed.
I'm currently running an i7-950 on a Asus Rampage Gene III LGA1366 motherboard.
Thanks.
Thanks.
