The return of the Turbo-Button?
The max turbo multipliers are stored in seperate registers from the "normal" max allowed cpu multipliers, and they can not be changed (unless you hack the cpu ) The turbo multipliers can not be forced to stay on all the time... at least not directly... you can fool the cpu into believing all the conditions that are necessary to run turbo mode are there, even if they are not
the highest boot multiplier is the highest "normal" multiplier...
for the i7-965 it works like this:
IF turbo is disabled
OR vcore is unstable
OR current is too high
OR Tdp is too high:
4 cores will run at 24x133=3200Mhz
3 cores will run at 24x133=3200Mhz
2 cores will run at 24x133=3200Mhz
1 cores will run at 24x133=3200Mhz
IF Turbo is enabled
AND vcore is stable
AND current is ok
AND the TDP is below the limit
4 cores will run at 25x133=3450Mhz
3 cores will run at 25x133=3450Mhz
2 cores will run at 25x133=3450Mhz
1 core will run at 26x133=3600Mhz
for the i7-940 it works like this:
OR Tdp is too high:
4 cores will run at 22x133=2933Mhz
3 cores will run at 22x133=2933Mhz
2 cores will run at 22x133=2933Mhz
1 cores will run at 22x133=2933Mhz
IF Turbo is enabled
AND vcore is stable
AND current is ok
1 core will run at 23x133=3050Mhz
so you see, turbo is really not that useful for most of the cpus, its only useful for the 965, where it basically auto overclocks the cpu... so basically the Core i7 lineup looks like this:
920 2800Mhz BUT if vcore is unstable, current is too high, or temps are too high, it will run slower.
940 3050Mhz BUT if vcore is unstable, current is too high, or temps are too high, it will run slower.
965 3600Mhz BUT if vcore is unstable, current is too high, or temps are too high, it will run slower.
What turbo really is, is a more advanced form of throttling the cpus from those clockspeeds down to a SAFE speed that will work even with high temps, fluctuating vcore and high current. instead of advertising a 3600mhz cpu that throtles down to 3400 or less depending on the situation, which would cause a lot of complains, the cpus are rated at 3200mhz and everything else above it is a BONUS, so nobody can complain
