- Mar 1, 2018
Just got my hands on the CM MasterLiquid 280PRO, try to run the Prime95 BLEND stress test and the temp of my CPU reach 100C! (as shown in Realtemp 3.7.0)
On some of the hardware review site they mentioned with the 280PRO even they run PRIME95 the temp never pass 81C.
Took it off and mount it again for 2 times but the result is still the same.
Any idea? could it be the cooler wasn't seated probaly?? Maybe it is not as easy as I thought?
My PC setup as shown below:
CPU: Intel I9 7980XE, OC'ed to 4.2 (sync all cores), Vcore 1.2V.
MB: ASUS R6E
Cooler: CM MasterLiquid 280PRO (Both fans were set to performance mode for maximum cooling)
Stress test: Prime95 Blend
Idle Temp: 41c
Max Temp: 100C (5 mintues after the PRIME95 blend stress test)
MB: ASUS R6E
Idle Temp: 41c
