- Oct 12, 2002
- San Diego
I'm new to setting up raid...
I have an IC7-G, w/ latest bios and 2 WD 80GB 8mb hard disks
I'm using the pata to sata converters on each then they are connected to sata1 and sata2 connectors on the mobo. All the power connectors are hooked up on the sata converters and the HD's are also hooked up correctly. I also have sata raid enabled in the BIOS...but when I boot up...I can not get into the raid menu via ctrl+s or F4...it says that primary and secondary channels are not found. I'm trying to do a fresh install of WinXP on the raid 0 setup, but I can't even get into the raid configuration menu....Can someone tell me what i'm missing or any tips...
Thanks...
Thanks...
