- Nov 16, 2003
- Cleveland OHIO
ok guys i posted about osme hard drives dying, when it turns out they werent dead at all. i have a gigabyte GA-7DXPDW. it has 4 ide channels.
well i was using the 3rd and 4th as just IDE channels. id always have a hdd on there wiht linux, so windows never saw it. well lately, i needed the extra hdd space so i put a win32 drive...big mistake..i got CONSTANT TIMEOUT ERRORS the whole computer did nothing but freeze.
i thoguht it was the drive, so i swapped it, then the cables, then i started moving things around. same problem. Linux has no problems running off of these channels...it works like a charm...so i tried putting a CDROM on there hoping thatd give results...sure it did, the result is i cant use my CDROM on that channel, it just freezes.
so i really dont know what to do guys. is it because im using the IDE channels as IDE and not RAID? thanks in advance.
