- Jan 4, 2010
OK, I've had my custom computer for a wile now and its a decent computer, but I hope to get a little more juice out of it.
Here are the full specs (According to CPU-z and my knowledge)
Motherboard: ASUS P4P800se
BIOS: American Magatrends Inc.
CPU:Intel Pentium 4 (Northwood) 3.0ghz Socket 478 mPGA 800mhz fbs
RAM:512mb pc3200(142mhz), 1024mb pc3200(200mhz), 512mb pc2700(166mhz), and a 512mb pc3200(200mhz). DRAM: 148mhz timings 2.5,4,4,8
Graphics: Nvidia GeForce FX 5500 256mb (NV34)
GPU: 270mhz, Memory: 400mhz
Cooling: Stock heatsink and fan, additional fans throughout tower (7 fans, including power source CPU and GPU fans)
So far I have managed to overclock the CPU to 3.33ghz (bus 221.9mhz, fbs 887.7mhz) with reasonable temps (idle: 29-32c, load 50-57c), and the GPU to 300mhz, but I cannot raise it any higher than that, otherwise windows won't boot, but I'm pretty sure it can go higher, because I've looked around and people have managed to get this cpu up to as much as 3.9ghz (though I don't have sufficient cooling for that, but I should be able to get a little more)
In addition my bios are particularly limited, there are 5 settings bus speed (100-400), Dram speed, AGP/PCI, CPU Vcore voltage, DDR ref, and AGP VDDQ.
The current settings are: Bus speed=222mhz, Dram=auto, AGP/PCI=auto, CPU Vcore=1.5375v, DDR ref=auto, and AGP VDDQ=1.5
Also any tips on safe temps for this CPU?
Any other advice, tips, suggestions will be greatly appreciated
