I just finished 12 hrs of Prime (Blend) @ 228 FSB: pass! That is 1:1 (sync) with RAM.
Now the funny thing:
- if I lower the FSB (and the CPU speed below stock) and just test the RAM (so, async), errors occur at speeds above 228 (Memtest 5 only). At 228, it passes all the tests looped with no errors.
- if I raise the FSB up to 230 and use dividers on RAM (async again, so it wouldnt be an issue while testing the mobo only), I cannot boot - the screen goes blank (monitor off). But with 228 (as mentioned above), I can not only boot, but pass the Prime so its perfectly stable.
Kinda strange dont you think? I mean, mobo and RAM peaking at the same speeds? Or maybe Im just lucky...Or could it be that the only reason I cannot go reach or go above 230 FSB is that dividers I use for RAM and CPU arent the "best" ones and thus make RAm or CPU work with "strange" speeds (by strange I dont mean too high...) Anyway, so far Im very happy with what I have. After all, its value RAM.
As for the CPC, I cannot set it in my BIOS so I guess its running 1T as you said then. One of many reasons I would like to try the moded BIOS also. And the L12 pin mod - same. I would much rather see it come with BIOS since I dont like to take my rig appart agin(done that to many times lol). I was said to use
THIS guide to help me get what I want (that would be the 10,5 multiplier in my case) but have realy no idea if this mod will the block the other multiplier and voltages settings in BIOS or not. Cuz who knows, maybe I will need to change either of it and with the pin mod blocking me I would have to tkae everything appart again. Oh BIOS BIOS, where are you?
Good luck on your overclocks - until later.....
Cheers!
