- Sep 21, 2002
- Denver, CO, USA
I am able to play 1080p with my Atom 330 using the CoreAVC codec. The right codec can make a difference.
I am still going to say that the 1000he has the best keyboard of all. Just tested an Acer Aspire and MSI wind. 1000he blows both out of the water...
I have tried the Acer Aspire One and I agree that its keyboard blows. I haven't tried the other two.
The best 10" netbook keyboard for several reviewers is the Samsung N120, which is 97% normal size. Samsung's trick is to make the chassis about 1/2" wider, but the weight is only 2.8lbs (compared to the 1000HE's 3.2lbs).
I think you're right about 1080p on a 10" netbook. The 1920x1080 resolution of 1080p far exceeds what any of these systems can display.
For me, it was the size. My fingers were squished together. When I demoed it, I also demoed the HP Mini 1000. The HP, which is just a tad smaller than the NC10 keyboard, was much more comfortable than the Acer.I really don't see why people dislike the AspireOne US keyboard. It is the same layout as the samsung nc10 (which used it since it came out much later) which everyone loved.
But in all honesty, if your using your tiny little netbook to play 1080p... You should really be in a different market. I can understand 720p or 1080p playback to a HD screen (In this case I would use a HTPC). But not on this tiny 10" screen. 700MB rips still look great when your sitting normally and not hunched over with your nose touching the screen...
The problem with this lies in the fact that one has to start with a 1080p rip, and then re-encode down to a smaller file size just to cater for the netbook. I'd like to be able to keep the original files, and simply transfer them to the netbook when I feel like it, with the only time consuming process being the actual transfer, not the hours (day?) worth of re-encoding. These netbooks are coming with 120GB+ hard drives with very minimal software installed. Even before removing the bloatware and unneeded system software, there is still plenty of space left to store a few stripped down BD rips with ease, which is how their stored on my HTPC in the first place.
Older laptops are normally larger then current netbooks, as well as underpowered (if you really go for one priced around current netbooks, you'r looking at something a number of years old), and/or still a higher cost even used then current netbooks. Alot of laptops only a year or two old, also have trouble with 720p video, let alone 1080p.
And yes, I do get regular emails from various online vendors with specials on laptops, which sometimes are very close in price to what netbooks are currently going for (most of the time refurbs...).
But I'm not looking for a laptop. I'm looking for a netbook.
Sounds more like you're looking for notebook power in a netbook form-factor. Netbooks weren't designed for what you want out of it.
Anyway, what I'm looking for is the power of a portable HD player in a netbook, not the power of a laptop in a netbook.
Sorry for this rant, but I feel like I'm being told to go buy a 360 when I'm asking about a Wii. If I wanted a 360, I'd ask about a 360 and not a Wii. Likewise if I wanted a laptop, I would have bought one ages ago.
I figured out what I wanted (10" Asus Eee 1000H) in advance and when I found it in the OCF classifieds for $250, I pounced in an instant. Keep and eye out there as they pop up and usually are a great deal.As my second attempt at a killer deal laptop, I was just about to click the buy button on an 8.9" Acer Aspire One A150 laptop. I stopped seconds short of clicking the buy button to double check and confirm that I can upgrade the RAM on that netbook. It turns out the thing has 512MB of RAM soldered on and one extra slot. As the max ram for a netbook is 2GB, this one is capped out at 1.5Gb. Yet another deal breaker on a discount netbook.
lenovo s12 with ION chipset when it comes out?
