- Apr 7, 2002
- Seattle
I just received 6 shiny new Gentle Typhoon AP-15's from Aquatuning, and they could not be nicer. I was so excited to install them on my XSPC RX360 Rad, but I wanted to run some benchmarks first with my existing fans to set a baseline for comparison.
Previous fans - 3 x 120mm NZXT 1200 RPM Fans in Push, 2 x CM 200mm Megaflow 700 RPM Fans in Pull. This config cost me nothing for the megaflows since they came with my HAF X, and the NZXT fans cost $6 each from Amazon. Total $18 for this setup.
New fans - 6 x 120mm GT AP-15's in Push/Pull. Total $105 for this setup
All Temps taken with RealTemp 3.691. All tests run within a 2 hour window. Ambients are 20.5 C or 69 F.
Previous fans:
Idle - Max 33
3Dmark Vantage - Max 58
LinX - Max 71
Prime95 - Max 66
New fans:
Idle - Max 33
3Dmark Vantage - Max 57
LinX - Max 69
Prime95 - Max 65
All told, I gained 2 freakin degrees of temperature drop. In addition, these are way louder than my previous fans. These will most definitely make their way to the classifieds shortly...
I can't imagine I maxed out the cooling potential of the rad, considering it is a CPU only loop right now, with a 2500K @ 4.8 Ghz, Vcore 1.4 V.
Lesson learned I guess.
Previous fans:
Idle - Max 33
LinX - Max 71
Prime95 - Max 66
New fans:
Idle - Max 33
LinX - Max 69
Prime95 - Max 65
