Done some more poking around.
Interesting testing here, but note it appears to be paid for by Intel:
https://www.shroutresearch.com/blog...mance-and-implications-on-testing-methodology
Of particular note, it seems that keeping the CPU in an active state can have a significant impact.
Putting aside various claims, I also tried to look at price per capacity position, expressed in £/GB. My pricing is from one major UK e-tailer who is the only one I found taking pre-orders so far, apart from the enterprise part I had to look elsewhere to get values.
We have 3 classes of Optane product so far: enterprise SSD, consumer SSD, consumer HD cache. The enterprise SSD I'm finding hard to get pricing on, but it seems to work out just over 4.0. Consumer cache works out 2.3 to 2.5. The 900p SSDs work out 1.3 - 1.4. In general, bigger capacity per category is slightly better value.
Into conventional high end SSDs, 960 Evo works out 0.43 to 0.47, 960 Pro works out 0.55 - 0.58. That puts Pro around 25% more than Evo, and 900p is up to 2.5x the Pro. Yes, that's a hefty price premium... so you're going to have to be pretty sure it is worth it to buy the 900p.
What about as ram substitute? If I just find the cheapest DDR4 16GB kit, that works out £9/GB, so over double the enterprise Optane, and 6x - 7x the 900p. I don't know where the ram-substitute Xpoint pricing will fall, or how that compares to the more likely ECC ram used in enterprise workloads. Obviously whoever might eventually buy this stuff will need to look at the best combo for their use case.
On competition to Xpoint, I have now seen vague references to Z-NAND and Z-SSD. I guess this is the "Gen Z" Dolk mentioned yesterday, but I didn't find it at the time due to the name difference. I've not turned up much information on it, other than claims of lower latency than conventional nand, allowing it to be a possible Xpoint competitor. I look forward to finding out more but for now there is nothing like a 900p.
The UK place I'm looking is claiming stock on 10th so just over a week away. I'm not going to pre-order to keep my options open as others should get it around the same time and I can see if there is any wiggle room for pricing.
