- Jan 4, 2005
At the beginning of June this year, Intel released a new generation of framework as scheduled, with the model name of Haswell
The pin of the last two generations is LGA 1155. It is the biggest difference that the new platform is changed to LGA 1150.
In a short time, Intel Core i series has advanced to the fourth generation of framework with better specification for each generation
The code of the most advanced chipset is Z87, bringing out the six SATA3 interfaces which have been waited for by many people for a long time
And CPU has recovered to the ability to exceed external frequency in the first generation of Core i, while the two aspects are both good improvements
The MB is BIOSTAR Z87X 3D, imitating design of Hi-Fi material as well
PCB uses black mist side material, cooling fin is blue, and color of appearance is similar to that of a middle and advance-level Z87
Hi-Fi Z87X 3D uses Z87 chipset, price of which is relatively fair compared with other brands in material and design
At present, BIOSTAR launches two Z87s in Z series, the other is Hi-Fi Z87W, belonging to a cheaper version
Intel has entered the fourth-generation framework of Core i series, names of CPU also begin with 4
The testing focus is the most advanced Core i7-4770K in Haswell framework, the codes followed by k all have function of adjusting doubling frequency
The CPU radiator is on the right, for 4 Cores CPU, Intel all uses radiators with copper material at the bottom
Total frequency of 4770K is 3.5GHz, supporting Turbo Boost technology, and top performance can reach 3.90GHz
Entity 4 Cores is integrated with Hyper-Threading technology, which can reach 8 threads in total, called 4C8T for short
It has the same 22nm manufacturing process with Ivy Bridge, with higher consumption of 84W, and 8MB of L3 Cache in total
Lower left of the main board
2 X PCI-E X16 3.0, supremely supporting AMD CrossFireX/nVIDIA SLI technology, and bandwidth is X8 + X8
1 X PCI-E X16 2.0, bandwidth is X4
3 X PCI-E X1
Network chip is Realtek RTL8111F
Sound chip is Realtek ALC898, highest to 8 sound channels of Blu-ray Audio and THX TruStudio Pro technology
Lower right of the main board
6 X black SATAs, offered by Z87 chipset, in the specification of SATA3
The above can establish RAID 0, RAID 1, RAID 5 and RAID 10 in a mix way, the maximum performance of which depends on the SATA device installed
Power / Reset button and LED debugging light signal, black of the upper part is a front USB 3.0
Upper right of the main board
4 X DIMM DDR3, supporting DDR3 1066~1600 / 1866~2800(OC)
DDR3 can supremely support 32GB,supporting Extreme Memory Profile technology, and 24-PIN power input is on the right
Upper left of the main board
CPU on both sides have enhanced passive thermal modules, and 8PIN power input is on the upper side
IO
1 X PS/2 keyboard
1 X D-Sub / DVI-D / HDMI
4 X USB 2.0(black)
2 X USB 3.0(blue)
1 X RJ-45 network hole
6 X Audio sound holes
