Intel SSD 320 Series MHDD ata password incorrect.
Flashek
Hi! :)
I had a problem with "8 MB BUG" in the Intel SSD320 drive (SSDSA2CW080G3).
Acting according to the guide, I recorded MHDD on the pendrive in version 4.6.
By entering the first "PWD" command, I blocked the drive with the "PASSWORD" password.
But when using the next "FASTERASE" command and using exactly the same password, the program displayed the message "FAIL".
My mistake is probably the fact that I used the IDE> SATA adapter for this.
As a result, my drive shows the full capacity of "80 GB"
but it is blocked.
Interestingly, the program can not initiate the drive, for example in windows or linux, but I can perform disk wiping (WIPE).
when :
hdparm --user-master u --security-erase "PASSWORD" /dev/sda
i/o read write error, NULL password dont work.
I dont care about data.
I am asking for your help and please tell me if it's worth anything to do with it :c.
Edit. In the integrated circuit is the normal winbond erpom. I am able to desolder it and reprogram it. Can be a password there?
Greetings and happy holidays
Partition magic:
Code:
/dev/sda:
ATA device, with non-removable media
	Model Number:       INTEL SSDSA2CW080G3
	Serial Number:      CVPR1112003D080BGN
	Firmware Revision:  4PC10302
	Transport:          Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6
Standards:
	Used: unknown (minor revision code 0x0029)
	Supported: 8 7 6 5
	Likely used: 8
Configuration:
	Logical		max	current
	cylinders	16383	16383
	heads		16	16
	sectors/track	63	63
	CHS current addressable sectors:   16514064
	LBA    user addressable sectors:  156301488
	LBA48  user addressable sectors:  156301488
	Logical  Sector size:                   512 bytes
	Physical Sector size:                   512 bytes
	device size with M = 1024*1024:       76319 MBytes
	device size with M = 1000*1000:       80026 MBytes (80 GB)
	cache/buffer size  = unknown
	Nominal Media Rotation Rate: Solid State Device
Capabilities:
	LBA, IORDY(can be disabled)
	Standby timer values: spec'd by Standard, no device specific minimum
	R/W multiple sector transfer: Max = 16	Current = 16
	DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5 udma6
	     Cycle time: min=120ns recommended=120ns
	PIO: pio0 pio1 pio2 pio3 pio4
	     Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
	Enabled	Supported:
	   *	Security Mode feature set
	   *	Power Management feature set
	   *	Write cache
	   *	Look-ahead
	   *	Host Protected Area feature set
	   *	WRITE_BUFFER command
	   *	READ_BUFFER command
	   *	NOP cmd
	   *	DOWNLOAD_MICROCODE
	    	SET_MAX security extension
	   *	48-bit Address feature set
	   *	Device Configuration Overlay feature set
	   *	Mandatory FLUSH_CACHE
	   *	FLUSH_CACHE_EXT
	   *	WRITE_{DMA|MULTIPLE}_FUA_EXT
	   *	64-bit World wide name
	   *	IDLE_IMMEDIATE with UNLOAD
	   *	WRITE_UNCORRECTABLE_EXT command
	   *	{READ,WRITE}_DMA_EXT_GPL commands
	   *	Segmented DOWNLOAD_MICROCODE
	   *	Gen1 signaling speed (1.5Gb/s)
	   *	Gen2 signaling speed (3.0Gb/s)
	   *	SMART Command Transport (SCT) feature set
	   *	SCT Write Same (AC2)
	   *	SCT Error Recovery Control (AC3)
	   *	SCT Features Control (AC4)
	   *	SCT Data Tables (AC5)
	   *	Data Set Management TRIM supported (limit 8 blocks)
	   *	Deterministic read ZEROs after TRIM
Security:
	Master password revision code = 65534
		supported
		enabled
		locked
	not	frozen
	not	expired: security count
		supported: enhanced erase
	Security level high
	2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50015179595043db
	NAA		: 5
	IEEE OUI	: 001517
	Unique ID	: 9595043db
Integrity word not set (found 0x0000, expected 0xa2a5)
Do you have a usb cradle you can use to connect the problem drive to another windows computer?
Yes i can. But on another computer seems to be the same situations. When i connect SSD to another computer with enabled ahci, intel ssd toolbox have an update for this intel SSD, but he asking for ATA password
Code:
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
PS C:\Users\Administrator> diskpart
Microsoft DiskPart version 10.0.17134.1
On computer: DESKTOP
DISKPART> list disk
  Disk ###  Status         Size     Free     Dyn  Gpt
  Disk 0    Online          238 GB      0 B
  Disk 1    Online         1397 GB  7168 KB
  Disk 2    Online         1863 GB  7168 KB
  Disk 3    Online          465 GB  6144 KB
  Disk 4    No Media           0 B      0 B
  Disk 5    Online           74 GB    74 GB
DISKPART> select disk 5
Disk 5 is now the selected disk.
DISKPART> clean
DiskPart succeeded in cleaning the disk.
DISKPART> list disk
* Disk 5    Online           74 GB    74 GB
DISKPART> create partition primary
DiskPart has encountered an error: Błąd danych (CRC).
See the System Event Log for more information.
DISKPART>
MHDD show that there is ATA Password. Intel SSD Toolbox show ATA Password too
You said you don't care about the data. So for such a small storage device I wouldn't spend a ton of time trying to fix this. I would just get a new bigger one and move on. Someday when you aren't focused on it the answer may come.
