- Jun 20, 2003
- Long Beach, CA
Abit IC7 Max 3
2.8E
2 x 512 Corsair pc4000 (3-4-4-8, stock)
Sparkle 400W psu
Zalman 7000cu w/ AS5
The mo bo & cpu are 2 weeks old, the memory is a few days old and the rest is well worn in.....
I was running 2 x 256 Mushkin basic (pc3200, stock timings)and able to hit 235fsb (1.38V) and run P95 with no probs, any higher FSB and it wont boot.
This is all at 1:1, which is what I want.
Now with the Corsair here's what happens in P95:
230fsb, 1.38v= all good, no errors
235fsb, 1.38v= tested fine 2-3 times, but did get errors once at 9 minutes in.
235fsb, 1.41v= all good, no errors
240fsb, 1.41v= boots, but random reboots and screen gets all whacked out
240fsb, 1.43v= same as above
Temps are at 49-50 idle and around 65 after running P95 for 24hrs, idle tems were the same even at 1.43V. Is it possible to get this sucka at 250fsb?
Is my setup too new and needs time to break-in (I got the memory last Fri)?
Need more volts?
Also, I have my Radeon running at 360/310 if that matters!?!?
Lastly, what test(s) should I run in P95? I usually run the random one where it stresses a little of everything and lots of RAM.
2.8E
Sparkle 400W psu
Need more volts?
