Yes, that is the one I was counting on - coming up on the last stage on my Windows 8 install now and found out the hard way it does not have that feature.
So that is the only thing I am missing now in Windows 8 64-Bit, redduc900. Removal of right click intruders w/o going into registry to do it manually.
I would also prefer to find a better startup interceptor. I am talking about trying to find a freeware 64-Bit version of this:
http://www.mlin.net/StartupMonitor.shtml
A true life-saver program since Windows 95 - and probably the ultimate reason I never switched to 64-bit Vista or 64-Bit Windows 7. It intercepts anything trying to register itself to run at startup - giving me the option to allow it or not - it kept all my 32-Bit computers running faster than they would have otherwise for the last 15 years.
I found this freeware to intercept startup insertion attempts but it is buggy:
http://tcpmonitor.altervista.org/download/?did=15 [If downloading the installation files, be sure to DECLINE ALL Download End User License Agreements to avoid installation of additional unnecessary software.]
[You will hear an annoying ta-da sound when starting the program. Immediately click on OK then right click on the program icon in Task Bar [lower right] > Options:
UNCHECK: Alarm when detect registry change. Delete unnecessary VirusTotalUpload.exe file from program directory.]
I got word of this program, which appeared to be free:
http://www.winpatrol.com/
However, the free version alerts you with a 3 minute delay, which can only be reduced down to a 1 minute delay. Real-time alert is only available in the PLUS version. So thirty bucks just to intercept startup entries if you have no need for other features.
On the wish list is also something I never heard of exists - it would be really cool if there was a program to also intercept Right click > New intruders in real-time. I need to keep the right click menu clean because I use it for a couple of specific things, and if they are the only ones in there - it makes superfast computing faster for those of us that are able to do things things in 0.1 seconds instead of 0.5 seconds.
