link to the fan i plan on useing for push pull:
http://www.performance-pcs.com/cata..._info&cPath=36_1130_69_1057&products_id=25751
well with the case im using 38mm fans wont cut it as they are to big for what im doing
3mmH2O won't cut it for a 30fpi radiator.
Really??? What is the standard for a high FPI rad? I would think that would be enough. The question is how accurate is it.
i think im going with the fans rustylivz posted look im going to have push pull on all three rads so im not worried to much about it at this point. if the fans i get end up being worthless then ill go look for something crazy like a 3000rpm fan. for now ill stick with the B-blasters
