I have a Gigabyte Z87X-UD3H with a F5 Bios sporting a i5 4670. I've scoured the net with bunches of overclocking guides and it seems I've turned an easy overclock into one that doesn't work after 4.4 Ghz. The numbers show correctly in the UEFI but incorrectly in Win7 using Cpu-Z, Hardware Monitor and OCCT, and yet I can use Gigabyte's Tweaking Utility in Windows at 4.7 Ghz and it displays and runs fine ... well mostly. I get about 30 minutes into OCCT with the Small Data Set and crashes .. but then again, I haven't tweaked it to work at 4.7. I don't understand why it always shows 4.2 or 4.4 until I run the Gigabyte utility ... and then it will show fine. Windows is not recognizing the settings in the bios after 4.4 ??? I'm blue in the face .... I must be overlooking something simple?? Or maybe I'm too simple .....
