- Aug 7, 2002
- Arlington, VA
here is a site with pics of my work during the mod.
http://web.ics.purdue.edu/~hidlebac/mod.html
click on the thumb nails for larger pics.
I was bored tonight, so i decided to finally do that usb and gameport mod that i've been talking about for like 3 months .. It turned out ok. Its like 99% done. I need to do a little more cleaning up on my cuts for the gamepad and also i didn't have a screws for it... so i just used twisty ties to temperaly hold them in place
So what do you guys think.... I know its rough but this was actually my first time using a dremel. For every other mod i have done, I used a sabersaw and a hole cutter for a drill. Way i look at it is, you gots to start somewhere .....
So basically i used a dremil and a drill.... also i had to do some cuting of the metal in my case(that was a pain). The sparks were flying everywhere.... But its cool, back in my concrete pouring days, i used to use diamond tipped concrete saw to cut 2 inch steel reehbar...
but anyways.... its so much easier having this stuff in front... why didn't i do this along time ago....
