- Jul 31, 2004
I also recently purchased a constellation and SMART parameters are not too good.
Code:Value Worst Thre. raw value 1 Raw_Read_Error_Rate 0x000f 066 066 044 Pre-fail Always - 70342312 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 960
Value and Worst of Raw_Read_Error (66) are quite close to the threshold (44)
Also G-Sense_Error_Rate (but I use HDD Removable Frames) displays an enough high value (960)
1. If you read the thread, you'll note that the numbers printed by smartctl are probably bogus. Check the values in Windows, or figure out how to get Seagate drives into the smartctl database.
2. 066 and 044 might be close. They might be projected decades apart. Seeing as "Worst" is 66, 44-66 might be the entire possible range, meaning it's as far from being close as possible. Lots of SMART values simply cannot be treated with simple integer arithmetic.
Tangent: There are at least a few threads on WebHostingTalk by people who are angry their server companies charge drive replacement fees after replacing a "bad" drive multiple times. The SMART data in each instance actually said the drives were okay, and replacing them was rather pointless. TL;DR: If you're not absolutely sure what a value in SMART means, and the tool doesn't print a big warning saying "YOUR DRIVE IS FAILING" (the simple "Pre-fail" or "Old_age" column is just listing types - it doesn't count as a warning), then you probably don't need to worry about it.
