- Dec 25, 2004
Since I've been confusing people, here is a bit of background.
The Hydra has been my (theoretically) 7 video card (AMD) system for mining and folding. It never really made it to 7 stable, so it tended to run 6 card, though I was down to 4 for the last couple of months due to fan failures and the like.
I decided to switch the Hydra to team green and linux for higher ppp / less electricity use. So I set up another system and started buying 970s as I got the chance. I just recently got the 3rd 970, and it wouldn't fit on the small test bench I was using for the new system. I was getting 300K to 330K ppd per card on it. It is a moderately older system, i7 860, but it has 4 16X slots and 2 1x slots, so it should make a decent 'Hydra'.
So, I took the MB, CPU, RAM, & OS HD and 2 of the AMD cards from the Hydra test bench and put it on the test bench that had the 970s. I took the MB, CPU, RAM, & OS HD and the 2 970s from that test bench and put it on the Hydra test bench. Then I added in the 3rd 970 and fired it up. Added the folding slot for the 3rd card in the client and it went to town.
However this morning, I see this:
However, I'm pretty sure I know what is going on thanks to a comment HayesK made a while back.
Other than adding in the 3rd card, the other change I made was to put the cards on 1x to 16x risers. I'm surprised there is that much of a hit though!
The other confusing thing in the mix is my main rig is dying, and I'm not folding on it at the moment. But I'm buying the hardware to replace it today. And as long as I'm buying hardware, I'm going to get some 16x to 16x risers and see if that solves my problem.
