- Oct 16, 2011
- New England
Looking for advice on rigid acrylic rebuild, issues with current
Hey OC'ers!
After seeing quite a few builds using rigid tubing, I've realized how much I like it. I need to do some loop maintenance anyways, I figured its a better time than any to replace. I currently use the WC kit in my signature and am looking for advice from general community but mostly anyone that has worked with the material. I had noticed someone mentioning this so as it stands now will be the brand tubing I am planning on buying but obviously I have no preference to brand as I just want quality so input on that would be great too, or other options. As far as the parts list I'm not particularly sure on needs. Performance PCs listed an E22 push fitting so I am wondering if thats all I need. I'm very open to advice as far as options/alternatives to this brand etc etc.
Two other questions I have is with the rigid acrylic route, could anyone give me advice as to where I might install some sort of T-line/drain for the loop? This is a stock photo I found and laid out my loop with my intense MS Paint skills to give an idea of layout. I guess part two of this question would be does an rigid acrylic loop have one to begin with? I guess it sounds silly in my head but I figure it's better to ask and look silly than to not and be a fool. As a side note this loop is CPU only, I had originally planned to cool my GPU down the line but it wasnt reference and I didnt not like the look/idea of the options for my GPU.
My last question that I can think of right now is liquid. When I bought my xspc kit they included XSPC ec6 but I'm wondering if plain distilled water is the best idea or if any of those deionized etc etc liquids are worth it or they're just gimmicks. Part two of that question is kill coil vs liquid additive because I still have a fairly full bottle of dead water biocide but I wasnt sure if this is something that is only meant for certain types of liquids as it says coolant biocide additive or if it can be used in any types of liquid you'd find in a loop.
Hey OC'ers!
