- Mar 7, 2008
Doing my usual youtube scan this morning, the first part of this video may be of interest here. In short, take some gallium, add indium, and it turns liquid. This combo is well known, but this is the first time I seen it done in practice in this way. The addition of a small amount of tin can reduce melting point further.
I've done delids and used a regular 1g tube of Conductonaut which has done about 5 applications so far with an unknown amount remaining. I've limited use to under IHS only but if it were cheap enough, you could use it anywhere (where there isn't aluminium anyway).
Looking first on ebay I found some indium quickly, but no gallium. amazon.co.uk had a few vendors. It will be an area for future research but based on https://en.wikipedia.org/wiki/Galinstan you'd be looking at roughly 3 parts gallium to one part indium, with a smaller than indium quantity of tin. Roughly speaking, I think I could make around 30g of galinstan for a comparable cost to buying a 5g tube of Conductonaut.
There will be some risks and unknowns of course, maybe some ratios are better or worse in this use case. Purity of the samples used might have unknown effects, and that's not even thinking about the potential longevity of it. Given my low usage rate it is just easier for me to buy more Conductonaut if I need it, but this could be a future video for a tech tuber...
