- Nov 7, 2004
I found this site that guides me on how to create a recovery of windows 7
http://ccm.net/faq/4093-windows-7-create-a-recovery-partition
In my rig below is a Sandisk 128GB SSD it's not the fastest out there I think it's sort of low end spec that was £40 but a friend gave it to me I would like to use that as my recovery drive in case my W7 would screw up but is it possible for me to create that on the SSD and if all else fails just make set-up run from that drive by pressing F12 etc and then running the install, will this guide do that for me when I need it. I don't want it to try and load it every time I boot my PC up just when I need to do a re-install of W7 as a fresh install is probably the best.
What about the built in Windows 7 Image back-up will that always work?
