SeasonalEclipse said:
what board do you use?.. there should be a PCI lock on it to keep it locked down at one speed.
Board is Asrock Conroe945G-Dvi and before you say it..i know its not the best ocing board, but for a budget board its fine.
I currently have a e6400 in it running at 301x8 FSB and mem running in 1:1 ratio @ 3.3.3.8
The only problem is that to get the PC to post over 299 the pcie frequency has to be increased.
At the moment i am running it Async but pcie freq is manually set to 101 to allow it to post, my systems been stable for 3 weeks now, but i know the e6400 can go up more, but the pcie is limiting it atm, i dont want to increase it so much that it kills my 7600gt, ive heard various reports that 105 to 120 pcie freq is safe, but have never found a true answer to the question.
FSB on the board is limited to 350FSB at the moment unless they bring out a new bios with more features, but for a budget board im not sure thats on their to do list.
Anyway, my aim is to try and get 2.6ghz or 2.8ghz if possible, ive heard about using a software program called Clockgen, but how viable is it really?
Would much prefer to do it via the bios which i find alot easier.
Anyway, thats about it from my end...thanks for the input so far.
