- Apr 27, 2004
Long story short, 2 drives failed in a raid6 - replaced both drives - --add drives to the array - mdadm spends a day rebuilding and all is well - till I rebooted. "Failed to mount /mnt/nas blahblah /dev/md5 not ready" - here is cat /proc/mdstat:
The two drives replaced were /dev/sdc1 and /dev/sdd1 - you can see it has /dev/sdd1...but for some reason it's listing /dev/sdc? It's partition 1 that should be there and not just the straight disk (my array has 4k af and 512b drives mixed). mdadm --examine /dev/sdc1
what's weird is when I tell mdadm to examine /dev/sdc and not partition one:
There is the old failed array...
stopping and force starting...
mdadm -D /dev/md5:
cat /proc/mdstat:
Any hints tips or suggestions on how to correct this? Once force assembled everything is 110% on track and a-ok.
Code:
root@rommie:~# cat /proc/mdstat
Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
md5 : inactive sdh1[7](S) sdf1[5](S) sdg1[6](S) sda1[1](S) sdd1[3](S) sde1[4](S) sdb1[2](S) sdc[8](S)
15628107008 blocks
unused devices: <none>
Code:
root@rommie:~# mdadm --examine /dev/sdc1
/dev/sdc1:
Magic : a92b4efc
Version : 0.90.00
UUID : c0370395:f845630f:26c640ad:ebf0ffa6
Creation Time : Sat Mar 12 16:43:53 2011
Raid Level : raid6
Used Dev Size : 1953511936 (1863.01 GiB 2000.40 GB)
Array Size : 11721071616 (11178.09 GiB 12002.38 GB)
Raid Devices : 8
Total Devices : 8
Preferred Minor : 5
Update Time : Tue Jun 5 05:33:22 2012
State : clean
Active Devices : 8
Working Devices : 8
Failed Devices : 0
Spare Devices : 0
Checksum : 86970e0f - correct
Events : 3867051
Layout : left-symmetric
Chunk Size : 512K
Number Major Minor RaidDevice State
this 0 8 33 0 active sync /dev/sdc1
0 0 8 33 0 active sync /dev/sdc1
1 1 8 1 1 active sync /dev/sda1
2 2 8 17 2 active sync /dev/sdb1
3 3 8 49 3 active sync /dev/sdd1
4 4 8 65 4 active sync /dev/sde1
5 5 8 81 5 active sync /dev/sdf1
6 6 8 97 6 active sync /dev/sdg1
7 7 8 113 7 active sync /dev/sdh1
Code:
/dev/sdc:
Magic : a92b4efc
Version : 0.90.00
Raid Level : raid6
Raid Devices : 8
Total Devices : 7
Preferred Minor : 5
Update Time : Sat Jun 2 14:57:05 2012
State : clean
Active Devices : 6
Working Devices : 7
Failed Devices : 1
Spare Devices : 1
Checksum : 86939768 - correct
Events : 3866263
Chunk Size : 512K
this 8 8 32 8 spare /dev/sdc
0 0 0 0 0 removed
3 3 0 0 3 faulty removed
8 8 8 32 8 spare /dev/sdc
Code:
root@rommie:~# mdadm -S /dev/md5
mdadm: stopped /dev/md5
root@rommie:~# mdadm --verbose --assemble --force /dev/md5 /dev/sd[abcdefgh]1
mdadm: looking for devices for /dev/md5
mdadm: /dev/sda1 is identified as a member of /dev/md5, slot 1.
mdadm: /dev/sdb1 is identified as a member of /dev/md5, slot 2.
mdadm: /dev/sdc1 is identified as a member of /dev/md5, slot 0.
mdadm: /dev/sdd1 is identified as a member of /dev/md5, slot 3.
mdadm: /dev/sde1 is identified as a member of /dev/md5, slot 4.
mdadm: /dev/sdf1 is identified as a member of /dev/md5, slot 5.
mdadm: /dev/sdg1 is identified as a member of /dev/md5, slot 6.
mdadm: /dev/sdh1 is identified as a member of /dev/md5, slot 7.
mdadm: added /dev/sda1 to /dev/md5 as 1
mdadm: added /dev/sdb1 to /dev/md5 as 2
mdadm: added /dev/sdd1 to /dev/md5 as 3
mdadm: added /dev/sde1 to /dev/md5 as 4
mdadm: added /dev/sdf1 to /dev/md5 as 5
mdadm: added /dev/sdg1 to /dev/md5 as 6
mdadm: added /dev/sdh1 to /dev/md5 as 7
mdadm: added /dev/sdc1 to /dev/md5 as 0
mdadm: /dev/md5 has been started with 8 drives.
mdadm -D /dev/md5:
Code:
root@rommie:~# mdadm -D /dev/md5
/dev/md5:
Version : 0.90
Raid Level : raid6
Raid Devices : 8
Total Devices : 8
Preferred Minor : 5
Persistence : Superblock is persistent
State : clean
Active Devices : 8
Working Devices : 8
Failed Devices : 0
Spare Devices : 0
Chunk Size : 512K
Events : 0.3867051
cat /proc/mdstat:
Code:
md5 : active raid6 sdc1[0] sdh1[7] sdg1[6] sdf1[5] sde1[4] sdd1[3] sdb1[2] sda1[1]
11721071616 blocks level 6, 512k chunk, algorithm 2 [8/8] [UUUUUUUU]
