- Feb 21, 2008
- Baltimore, MD
OK. So I'm going put together a new PLEX server that will double as a NAS. I have some questions from those more familiar with FreeNAS and other storage solutions.
First here is my proposed plan.
I picked up a server off ebay:
Supermicro 3U chassis: CSE-835TQ-R920B
-8x 3.5" hot swap bays
-2x 5.25" bays
Supermicro X9DRi-LN4F+
-onbaord 4x Intel Gigabit LAN
48GB (12x4GB) DDR3-REG
2x Intel Xeon E5-2650L (will be swapped for 2x E5-2680v2)
1x500GB WD 7200RPM drive (meh, will be swapped for an SSD for OS)
2x 1280W (really 1000w @110v) redundant/hot-swap PSU
after a few days of research I think i decided on the storage configuration.
8x2TB drives to start
FreeNAS (ZFS)
pool = 4x mirror vdevs (which if i'm understanding correctly will be essentially raid 10, yes?)
Advantages I see:
-Speed. this will essentially be 4x mirror vdevs (raid1), striped together (raid 0).
-Redundancy. I can have up to 4 disk failures IF AND ONLY IF they fail in separate vdevs
-Expandability. I could theoretically add more space by adding more mirror vdevs to the pool with more pairs of disks, OR (more similar to me since ill be populating all 8 of my drive bays) replace disks one by one to expand the individual vdevs.
-fast rebuilds. recovering from a drive failure only has to do a straight copy from the mirror on that single vdev. reducing workload on all other drives during rebuild.
-ZFS bonus - rebuilds only copy actual written data, not the whole drive bit for bit like other raid solutions.
Disadvantage:
-not great space efficiency (50% useable space)
-2 disk failures in a single vdev (taking out the whole vdev) kills the whole pool. (using RE4 drives however so i'm doing my best to mitigate that)
thoughts? am i correct on all this?
anyone think I'm doing something stupid here and want to recommend a different approach?
-2x 5.25" bays
FreeNAS (ZFS)
Advantages I see:
Disadvantage:
