Just built a new Ryzen 5 2600 (non x) gaming rig and joined overclockers, first post whooo!
I searched and there is a post about this topic, but I didn't want to resurrect a post that's over 1521 days old.
As mentioned above I have a R5 2600 (non x), ASUS Prime Pro x470, 16gb 3200MHz ram, and a Fractal S36 AIO with Corsairs HD120's. Using Ryzen Master, I can get the 2600 to 4.075 @1.375V. Anything more even with more voltage and the screen freezes and I need to restart. Maybe it's something deeper and not a thermal issue.
Regardless, my question is: can I do a push pull with the Corsairs HD120's and the Fractal fans that came with the AIO?
Here are the specs for both fans:
Corsairs HD120s:
800-1725 RPM
2.25 mmH2O
54.4 CFM
Max input current: .3A
Operating voltage: 7 - 13.2V
Hydraulic bearing
Dynamic X2 GP-12
500-2000 RPM
2.30 mmH2O
87.6 CFM
max input current: .2A
Operating voltage: 7 - 12V
LLS bearing
I'd want the Corsairs to be the push fans (because RGB) and the fractals to pull.
Thanks for any input / advice!
Corsairs HD120s:
800-1725 RPM
2.25 mmH2O
54.4 CFM
Hydraulic bearing
Dynamic X2 GP-12
500-2000 RPM
2.30 mmH2O
87.6 CFM
LLS bearing
