- Feb 10, 2012
Current computer specs
MSI-7390 sli V.2 Motherboard bios v.1.20
AMD 64x2 6000 3.0ghz
2x1gb ddr2 800mhz pc6200 ram
1gb nvidia gtx 550ti graphics card
500gb HDD
Windows 7 64bit
ok just bought a 4gb 2*2gb kit for my computer and want to install them with my current ram to get a total of 6gb.
when i install the 2gb ram in duel channel by themselves everthing works fine but when i install the 1gb in the secound channel the monitor doesnt turn on. so i figured i would go and check the timings
old ram is OCZ 1GB 800mhz pc6400 4-4-4-12 1t 2.1 volts
new ram is G.Skill 2gb 800mhz pc6400 5-5-5-15 1.8 volts
when i go into bios and check dram only has 2 options auto or DCT 0
also in the bios the memory voltage is set at auto 1.6v min and 2.3v max and it is grey'd out so i cant change it.
any suggestions would be great
500gb HDD
Windows 7 64bit
