Not that I am aware off but honestly with the choices you have for a CPU you will really not need one. I have a block on my CHVz and truthfully unless you are exploring the outer limits on an OC for daily use it really isn't needed.
Waste of money.
True words, but i have a A10-7850k and the stock speeds suck, so i decided to overclock this thing.Not that I am aware off but honestly with the choices you have for a CPU you will really not need one. I have a block on my CHVz and truthfully unless you are exploring the outer limits on an OC for daily use it really isn't needed.
I dont have the money for a new built (im 15) and i wont get an aio, becasue the mosfets are gona overheat with overvoltageing and high voltage frequency. I really need mosfet coolingNot worth the money you're going to have to drop on a custom loop with MB cooling. You're better off by saving up for a new system or at least wait and see what they have in store.
Just strap some fans to blow air over them!
I just did this on my AMD board where the heatsink was crazy hot but with a slow rpm fan blowing is cool to the touch. I would recommend doing this.
I concur.
hello,
just want to let you all know that i finished building my loop today (took me 1 day).
it runns at 4.6 ghz with chache frequenzy on 2100 mhz at 35 degrees celsius and with a r9 380 overclocked at 40 degrees.
i use 1 420 and 1 360 radiator, a kryos on my cpu, and a D5 in my define S..
i would say it was worth it
PS. blocks for the mb and the gpu will be aviable soon on Alphacool
