- Jun 12, 2009
Here are the parts i am discussing my issue on:
MSI 790GX-G65 AM3 AMD 790GX HDMI ATX AMD Motherboard
AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 125W Quad-Core Processor
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit
Ok, i am in the process of building this setup. My issue is, i installed the processor fine. The CPU Cooler went on fine, but the way the board is laid out and the location of the RAM make it so that Heatsink fins project over the bottom channel of the memory, and the memory i picked comes with a metal grip attached to the top of it. The grip is so that you can push the stick of RAM onto the mobo and not potentially dmaage any of the RAM stick itself. But the grip sticks up about .5-1 inch making the RAM too tall to fit under that heatsink (even then it'd be close).
What i'm wondering, is there anyway to put the cooler in the opposite way on the AM3 Mobo's? Also, could we remove those metal grips to make it easier to work with w/o damaging the actual integrity of the RAM?
Thanks guys.
Thanks guys.
