CaddyGuy420
- Apr 8, 2013
- MN
Question: Do you think It would be better to go with the ASRock Extreme 11 or get the MSI Big Bang-X Power II with a PCI-E addon card for additional SATA ports on a LGA2011 build?
The Setup:
I have a hard drive switch that I made for switching boot drives to swtich between 3 boot drives. So far I only have one hard drive that will be connected at all times for shuffling files back and forth (eventually want to do a 4 drive RAID 0+1 Setup). If anyone is wondering boot drives are for 1 Online normal use, 1 Offline isolated from the internet, 1 Gaming drive. I also plan on 4 optical drives. There is also a 2.5" HD Dock built into my case (Coolermaster Storm Stryker) that I would like to hook up as well. That makes my SATA needs as follows.
Initial build
3 - Boot Drives
1 - Storage Drive
4 - Optical Drives
1 - HD Dock
9 - Total SATA ports
Future Setup
3 - SSD Boot Drives
4 - RAID 0+1 Storage Drives
4 - Optical Drives
1 - HD Dock
12 - Total SATA ports
The question again: Would it be better to go with the ASRock Extreme 11 or get the MSI Big Bang-X Power II with a PCI-E addon card for additional SATA ports on a LGA2011 build?
Opinions on quality of board, reliability, and features would be greatly appreciated, as well as any other suggestions or ideas. I can also post pics of the HD switch if anyone would like to see it.
Thank you,
CaddyGuy420
The Setup:
Initial build
3 - Boot Drives
1 - Storage Drive
4 - Optical Drives
1 - HD Dock
Future Setup
3 - SSD Boot Drives
4 - Optical Drives
1 - HD Dock
Thank you,
CaddyGuy420
