- Jan 10, 2012
why water? mine are both cool, quiet and just get the job done with no drama at all.
Cause this case begs to be filled
I dont need to cool them but hell why not
The better question is why not?? lol
With enough rad and low speed fans this thing is dead silent. I literally can not hear my pc if there's anything else going on in my room. The only time it's really audible is when everything else is dead silent. So that's a good reason to go full water, imo. After coming from a totally air cooled build with a noisy 7970, to an even noisier 290x the silence is bliss lol.
They say you cant fit a Monsta 480mm rad up top in push/pull config but guess what
And no these are not the fans I am going to use
Just old ones to mock up stuff
Stuffed?? Not even close I still have room for a 480 & a 240 rads plus a 140 at the rear
Its the wallet that keeps getting empty on every order LOL
I also just recieved my replacement gpu so back to Xfire I go then some gpu water blocks Did my wallet just get lighter?
That feeling that the wallet keeps getting lighter will continue... its a curse! Once you start WC you can never get away! lol
