So far I got mine up to 2000 first try default voltage booted windows but unstatble prime gonna go up the voltage a tad and try for higher.
So far I still at 2000 tried going 2160 at 1.75 got to windows but was reall unstable then went to 1.85 and my computer shut itself off went 1.9 and it did the same I think I PU might be holding me back right now I'm buring in with prime 2000 at 1.75 any suggestions are welcome.
Got it to stop turning itself off by turning off watchdog timer on my Mobo. I think it is heat that is holding me back now as it is gertting pretty warm. I have an SK7 that should come tomorrow with a new fan as well that should help but in the meantime I'd like to burn it in what is the preferred methood take it as high as you can get stable throw as much juice as you're comfortable with and run prime? So far not a great OC but I'm satisfied and I think I can get it to go higher with the SK7 and some burning in.
Shawn
Shawn
