Hi guys ...
I tried a French forum but the guys there were not very helpful.
But I'm sure that you all be able to give me an advice about the items I have choosen for my 1st system ...
I currently use :
- Motherboard Asus P9X79
- CPU Intel Core i7-4820K
- Graphics Asus GTX770 DC2OC-2GD5 (getting this on next Monday)
- Case Corsair Obsidian 800D
I have planned to get this for the WC system (sorry it is on a French store website) :
1 x http://www.docmicro.com/pieces/Pad-Thermique-Ultra-Haute-Performance-5W-mk-100-100-0-5mm_8233.html
1 x http://www.docmicro.com/pieces/Plaq...rce-GTX-680-DCII-GTX-770-DCII-NOIR_10442.html
1 x http://www.docmicro.com/pieces/WaterBlock-VGA-EK-FC770-ACETAL_11248.html
1 x http://www.docmicro.com/pieces/Reservoir-Balancer-150-Silver_9407.html
8 x http://www.docmicro.com/pieces/Tuya...-13mm-externe-Au-metre-TRANSPARENT_10753.html
6 x http://www.docmicro.com/pieces/Embo...tuyau-10-13mm-Finition-Alu-Brillant_7357.html
1 x http://www.docmicro.com/pieces/Double-connecteur-10-13-Vanne-de-Vidange-VLV-10TSPL_9422.html
1 x http://www.docmicro.com/pieces/Liquide-de-Protection-Concentre-XT-1-Bleu-150ml_10986.html
1 x http://www.docmicro.com/pieces/Sond...tage-1-4-Male-Femelle-Afficheur-LCD_9812.html
1 x http://www.docmicro.com/pieces/Radiateur-RS360_7701.html
6 x http://www.docmicro.com/pieces/Vent...2-2000rpm-Noir-Edition-Silencieuse_11501.html
1 x http://www.docmicro.com/pieces/WaterBlock-CPU-EK-SUPREMACY-NICKEL-ACETAL_10426.html
Do you think I need something else ? Or maybe I can remove something from this list ?
I'm waiting for all your advices ..
Thanks in advance for your messages ...
LePousson
I currently use :
LePousson
