My First Build
Yea that makes sense. So the 2400 ripjaw would be even better then the 1866?
Theoretically, except the AMD FX series CPUs have an IMC (Integrated Memory Controller) that is not stout enough to take advantage of the 2400 mhz RAM. The IMC would not be stable at that high of frequency. Trust me, the 1866 mhz RAM is what is appropriate for your CPU.
Also I'm noticing the same things with video cards
Things like core clock 1020mhz etc...
Don't confuse the processing frequency of the GPU with the video card's memory frequency. Two different things. Processing frequency = core clock. With discrete (meaning a separate video card rather than onboard or APU graphics) GPUs, however, they can handle RAM with a very high frequency. Don't worry about all that too much. Worry more about the processing frequency of the GPU itself than that of the video card memory. Just get one with GDDR5 memory. Don't make this unnecessarily complicated for yourself. Further down the road it will make more sense to you as you have more do-it-yourself build experience.
One thing you never stated is budgetary restraints. If there are none then there are more powerful video cards available than the Radeon 280X but if money is at least somewhat an issue then it's a good bet.
It makes it very hard to choose. :(
Okay, if money is no object then go for Something on this page: http://www.newegg.com/Desktop-Graphics-Cards/SubCategory/ID-48
or
this page: http://www.newegg.com/Product/Produ...7709 600473871&IsNodeId=1&name=Radeon R9 290X
You can also go with two video cards connected by a bridge that operate in synergy and give even better performance. With AMD cards it's called "Crossfire" and with Nvidia cards it's called "SLI".
What about your PSU? If you start going with really potent video cards or multiple cards you will need a heft PSU to provide adequate power.
So the EVGA one seems liek the better buy for me currently.
I do not plan on running multiple monitors for a while.
At most 1 good monitor and an off the side monitor thats all.
So so far this will be my build....
http://pcpartpicker.com/p/bJJk8d
Getting there. :)
I planned on getting a little bit larger then necesary PSU for future reasons any who, so its perfect.
Blu Ray is preffered, yes
Bluray: http://www.newegg.com/Product/Product.aspx?Item=N82E16827129076
SATA cable x3: http://www.newegg.com/Product/Product.aspx?Item=N82E16812123282
Thermal Interface Material ("TIM"). This is the grease that goes between the CPU top and the cooler base to improve contact and heat transfer. The Corsair H100i will come with some pre-installed but if you mess up the first install or ever need to reinstall the cooler block it's good to have extra around: http://www.newegg.com/Product/Product.aspx?Item=N82E16812123282
Do you already have the monitor, keyboard and mouse? And will the computer be connected to the internet via a wired or a wireless connection?
I have some of the extra TIM.
I have everything, but I'm upgrading to new things, as I only have really basic stuff.
I'm open to all recomendations on them,
I read one forum here said the logitech 700 was a beast mouse.
I'm not a gamer so I can't really comment on those accessories. They have keyboards just for gaming too but I've never used one. I'll leave you to your own devices when it comes to those accessories. Anything else you can think of that you need advice on?
So far so good, If I run into any complications or have questions, Ill Either PM you or post on the thread again :)
