I'm on a fresh funtoo install ontop of a fakeraid 0 array. I've build my kernel from source and included my filesystem drivers and I used genkernel to build by initrd (so dmraid can load). Everything is working fine except my root is mounted wrong. Here are two lines I see in dmesg:
It mounts everything else fine including my /home which is ext4.
Code:
[ 0.223341] EXT4-fs: Unable to register as ext3 (-16)
Code:
[ 8.603928] EXT3-fs (dm-4): error: couldn't mount because of unsupported optional features (240)
[ 8.622661] EXT4-fs (dm-4): mounted filesystem with ordered data mode
Code:
# /etc/fstab: static file system information.
# The root filesystem should have a pass number of either 0 or 1.
# All other filesystems should have a pass number of 0 or greater than 1.
# NOTE: If your BOOT partition is ReiserFS, add the notail option to opts.
# See the manpage fstab(5) for more information.
# <fs> <mountpoint> <type> <opts> <dump/pass>
/dev/mapper/isw_cfcibibgej_RAID01 /boot ext2 noauto,noatime 1 2
/dev/mapper/isw_cfcibibgej_RAID05 none swap sw 0 0
/dev/mapper/isw_cfcibibgej_RAID06 / ext4 noatime 0 1
/dev/mapper/isw_cfcibibgej_RAID07 /home ext4 noatime 0 1
/dev/mapper/isw_cfcibibgej_RAID08 /mnt/ubuntu ext4 noatime 0 2
/dev/mapper/isw_cfcibibgej_RAID02 /mnt/windows ntfs-3g noatime 0 2
/dev/mapper/isw_cfcibibgej_RAID09 /mnt/storage ntfs-3g noatime 0 2
/dev/cdrom /mnt/cdrom auto noauto,user 0 0
/dev/floppy /mnt/floppy auto noauto,user 0 0
proc /proc proc defaults 0 0
shm /dev/shm tmpfs nodev,nosuid,noexec 0 0
