Istillusefloppy
- Oct 19, 2012
I know DELL what is this guy thinking!
I just wanted to share some shots from my recent project. I know my computer is a Pentium D relic but I love it and it has faithfully served me plenty images and videos of porn over the past 7 years and a couple games here and there, and some school projects tossed in. I modded out my dell about as good as she could be but of course I ran into some cooling problems.
The stock dell cooling system sucks for modified computers and mine was running constantly after I upgraded my processor.
I had to make a bracket for it to fit. I did this by removing the stock heat sink mount and used the holes to mount the bracket I made. It tight and not even zues himself coult pull it free.
The suck part was the face that the capacitors are in the way so you can't use any of the corsair brackets and customize them to fit. You have to make your own.
Here the type of clearance you get in the cramped Dell case fortunately the radiator reaches just fine to sit in the stock fan area. I'm using the stock fan attatched to the radiator. I'm not bothering with them.
Well that's about it. Other than that runs fine and has been cooling my computer just fine. So if you don't think you can run one of these in a BTX yah can. It's a little bit of work but the reward feels good.
