- Thread Starter
- #21
This is the case nearing completion. You can see that the diamond plat has been installed. As you can see the paint looks much better now after having the clear coat applied and sanded. Also pictured up top is the Danger Den fill-port and my Weapon radiator with shroud. Here you can see that paint looks much better. Also, the bottom looks a little rough, but I have an idea that will show up later on how to finish the bottom section.
Same as above but with the front face plate installed. There is going to be some mesh work in the front and the top.
Just a close up of the main part for the cooling system.
