If you want to put a link in, but you don't want the whole link to show up... what you can do is this.
[*url=www.something.com]LINK[/url*]
Haha I'm not used to this HTML style for this forum.. I wasn't sure how to do it. I guess I should of hit LINK and not IMAGE... blah!
HERE! =) Bimmerinfo.com
My RAM says Dual Channel when I boot... I would just try reseating it in banks 1&3 or 2*4 and see if that fixes the problem. You know RAM is picky sometimes just like PCI slots or AGP, sometimes the card or RAM just needs to be reseated.
Maybe I'll start PRIME tonight before I go to bed and let it run for about 16+ hours until I get back home from work tomorrow and see how it works. I have run it before without problems, but not for longer than 30 mins.
I did lower my temperature even more by around 3ºC-4ºC while Idling. What I did was I wanted to remove the stock Intel CPU Fan. Now, I realized once I had removed the fan that I could not lock the Heatsink into place because the Fan was built into part of the whole Intel LOCKDOWN of the heatsink.. So I just broke out the fan and used the shell which went over the Heatsink and then I was able to lock down the Heatsink. I was halfway done Next I angled a nice Panaflow 120mm fan slightly towards the NB (NorthBridge) chip directly and towards the rear of the system. I also placed a smaller 80mm Panaflow on top of the NB heatsink, after I removed that MSI eyecandy piece which was just resting on top of the NB heatsink... Otherwise it would of blocked airflow from both fans.
So basically... after removing the stock Intel CPU Fan I am now able to push more CFM directly over the heatink.... I could probably lower it slightly more if I was able to find another way to hold down the heatsink and remove the top portion that I currently need to hold down the heatink.. (I have no name for it).
If I decide to keep the setup in the current case, I will need to do some modding on the case because after I installed the ATI 9500 card it does put off some mad heat... but I think I am going to be making a custom Polycarbonate type of PC box, which will be used as a HTPC type of setup for this system, near my TV. I'm still working on the layout and how I want to let outside air into the system. I might even leave it open on the sides and just have 4 pillar like rods on the 4 corners to hold a top and bottom together.. as I said it's in the works.
So right now I'm right around 27ºC at idle with the side of the case off.. I'll watch it some and see what happens when I put the side on the case. I do know I need a bigger fan at the rear of the system. I took of the 120mm Panaflow to pass air over the CPU Heatsink and replaced it with an 80mm Panaflow with 1/4 less CFM. It's almost useless... That Panaflow is pimp heh it's got some noise but with the case closed it's not too audiable.
Ok!
That's it for now.
