Cptlucascrunch
- Sep 14, 2014
Ok so I bought a new pc for gaming about 2 months ago and it can't fit a gpu in so I'm just gonna build a whole new pc since it isn't that good anyway I'm planning to buy the case, psu and motherboard first then buy the new processor and a gpu along with a after market CPU fan a couple of weeks later, as my wage is quite low. I've decided too make my budget around £500 and would make the maximum around £700. Components like Ram and the hdd will be sourced from the other pc to save money, at the moment the the current list is:
Case £104.56: http://www.ebuyer.com/566875-aeroco...ium=products&gclid=CPn94svLz8ACFbPJtAodckMAOA
Motherboard £49.34: http://www.ebuyer.com/546762-gigaby...-1-channel-audio-atx-motherboard-ga-970a-ds3p
Processor £126.99: http://www.ebuyer.com/409184-amd-fx...mb-cache-retail-boxed-processor-fd8350frhkbox
Gpu £178.78: http://www.ebuyer.com/623869-gigaby...-displayport-pci-e-graphics-gv-r927xoc-4gd-ga
CPU fan £89.99: http://www.ebuyer.com/462121-corsai...h-performance-liquid-cpu-cooler-cw-9060014-ww
PSU £81.95: http://www.ebuyer.com/479894-evga-s...y-modular-80-gold-power-supply-120-pg-0750-gr
So thanks if you've actually taken the time to look through this and I'll look forward too seeing your suggestion on what I should change (if I should) or just post a whole new rig if you want and I'll check it out.
(I prefer AMD, I'm sorry to those who are going to post try an intel but there too expensive)
