cheetah999
- Jan 3, 2014
Hi all,
I need to troubleshoot an Intel E8400 (Revision E0) and a Gigabyte GA-EP45-UD3P bumped up to 4.0Ghz. Booting up to desktop and running the Prime95 for a couple of hours without any problem. However, when I started using the browser it gives me the blue screen with "Dumping Physical Memory to Disk" and rebooted. I was wondering if anyone can point out my error/s. My specs are below. Thanks in advance.
Spec:
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775
(w/ Tuniq Tower 120 Universal CPU Cooler)
Gigabyte GA-EP45-UD3P ATX Intel Motherboard
Corsair XMS2 8GB (4 x 2GB) DDR2 SDRAM 800 (PC2 6400)
Hitachi Deskstar 1TB 7200rpm SATA
SAMSUNG Spinpoint F1 1TB 7200rpm SATA
Seagate Barracuda SATA 300gig 7200rpm
Seagate Barracuda 160gig 7200rpm (IDE)
EVGA GeForce GTX 260 Core 216 Superclocked 896MB Video Card
Thermaltake W0099RU ATX12V 250 Watts (for video card)
Creative Sound Blaster Audigy 2 ZS w/Firewire
Pioneer 20X CD/DVD SATA Burner
Windows 7 x64 Ultimate
Sceptre 32" 1080p 60Hz LCD HDTV X328BV-FHD
Coolmax CP-500T (AP-600X) EPS12V 575W Power Supply
XCLIO Blackhawk Advanced ATX Full Tower Extreme Cooling Case
Spec:
SPECS:
CPU: Intel core2 Duo E8400 Wolfdale 3.0Ghz @ 4.0Ghz [Revision: E0]
MOB: Gigabyte GA-EP45-UD3P
RAM: 8GB (4 x 2GB) Corsair XMS2 DDR2 SDRAM 800 (PC2 6400)
Tuniq Tower 120 Universal Cooler
OS: 64Bit Windows 7 Ultimate
Disabled "Limit CPUID Max. to 3"
Disabled "CPU Enhanced Halt (C1E)"
Disabled "CPU Thermal Monitor 2(TM2)"
Disabled "CPU E1ST Function"
Changed "Init Display First" to "PEG"
MB Intelligent Tweaker (M.I.T.)
Robust Graphics Booster..................................[Auto]
CPU Clock Ratio..........................................[9X]
Fine CPU Clock Ratio.....................................[0x0]
CPU Frequency............................................[445 X 9]
>>Clock Chip Control
Standard Clock Control
CPU Host Clock Control...................................[Enabled]
CPU Host Frequency (Mhz).................................[445]
PCI Express Frequency (Mhz)..............................[100]
C.1.A.2..................................................[Disabled]
Advanced Clock Control [Press Enter]
>>DRAM Performance Control
Performance Enhance......................................[Standard]
(G)MCH Frequency Latch...................................[400Mhz]
System Memory Multiplier.................................[2.00B]
Memory Frequency (Mhz).....................800...........[890]
DRAM Timing Selectable...................................[Manual]
>>Standard Timing Control
CAS Latency Time.........................................[5]
tRCD.....................................................[5]
tRP......................................................[5]
tRAS.....................................................[18]
>>Advanced Timing control:
tRRD.......................................3.............[6]
tWTR.......................................3.............[6]
tWR........................................6.............[6]
tRFC.......................................52............[60]
tRTP.......................................3.............[6]
Command Rate (CMD).........................0.............[2]
>>CPU
Load-Line Calibration....................................[Disabled]
CPU Vcore..................................1.2500v.......[1.28750v]
CPU Termination............................1.200v........[Auto]
CPU PLL....................................1.500v........[Auto]
CPU Reference..............................0.760v........[0.863v]
>>MCH/ICH
MCH Core...................................1.100v........[1.200v]
MCH Reference..............................0.760v........[Auto]
MCH/DRAM Reference.........................0.900v........[0.970v]
ICH I/O....................................1.500v........[1.610v]
ICH Core...................................1.100v........[1.200v]
>>DRAM
DRAM voltage...............................1.800v........[1.940v]
DRAM Termination...........................0.900v........[Auto]
channel A Reference........................0.900v........[Auto]
channel B Reference........................0.900v........[Auto]
