need help deciding what laptop to buy
WoW_STORM
Alabama
HELP!!!
I am in the market for a new laptop and like everyone I want the best bang for the buck. I have looked at a lot of different deals and the more I look the more confusing it becomes. Any ideas of a decent laptop that cost less then $700.00 & has all of the basic features and not too horrible at basic gaming. No high res stuff maybe just a bit of FPS low res. No Crysis the like. LOL. I would like to have at least 1 gig of memory and as large of a hard drive as I can get.
How does the AMD turion compare to the Intel Core Duo and Core 2 Duo?
How does the video cards in the laptops I listed below seem to you folks?
If you know of a better deal please let me know.
I have found several deals at Office Depot. Here is the list of a few of them.
#1
Compaq C571NR
* Processor: Pentium Dual-Core T2080 (1.73 GHz)
* Hard Drive: 80 GB SATA, 5400 RPM (Hitachi HTS541680J9SA00, single platter, low power/noise)
* Display: 15.4" 1280x800 Widescreen BrightView (high gloss) (Samsung LTN154X3 Panel)
* Memory: 1 GB, 533MHz DDR2 memory configured in 2, 512MB sticks across both expansion slots.
* Memory Expansion: Up to 1 GB in each slot for a total of 2 GB
* Optical Drive: DVD +/- RW Burner with CD Burner.
* Graphics: Intel GMA 950 (On board video) with up to 224 MB shared memory
* Operating System: Windows Vista Home Premium
* Battery: 43 watt-hour lithium battery (appx 2 hours per charge)
* Expansion: 3 USB 2.0 ports. 1 Analog VGA port. 1 S-Video (TV Out) Port. 1 Microphone, 1 Headphone, 1 Ethernet Network, 1 Phone Modem.
#2
SONY VAIO N365E/B Notebook
Processor Class: Core Duo Processor
Processor Number: T2450
Processor Speed: 2.0 GHz
Front Side Bus: 533 MHz
Mobile Technology: Centrino
L2 Cache Size: 2 MB
System Chipset: Intel 945GM Express
Memory Speed: PC2-4200 (533MHz)
Memory Type: DDR2-SDRAM
Installed Memory: 1 GB
Maximum Memory: 2 GB
Memory Slots Total: 2
Memory Slots Available: 0
Total Hard Drive Capacity: 120 GB
Drive Controllers: SATA-150
Rotational Speed: 5400 RPM
Optical Drives: Double Layer DVD SuperMulti Drive
Sound Support: Digital Audio (16-bit)
Video Chipset Brand: Intel
Video Chipset: Graphics Media Accelerator (GMA) 950
Total Available Graphics Memory (Vista): 224 MB
Resolution: 1280 x 800
Screen Size: 15.4 in
Screen Type: Active Matrix LCD (TFT)
Physical Aspect Ratio: 16:10 (Widescreen)
Port Connectors: 1 x VGA out with Smart Display Sensor
1 x i.LINK® connector (IEEE 1394) (4 pin)
2 x USB 2.0
#3
Gateway MT6840 notebook offers:
• 15.4"-diagonal widescreen WXGA (1280 x 800) UltraBright™ LCD screen
• Intel Centrino Duo mobile technology
• Intel Core Duo processor T2450 operating at 2.0GHz
• 2MB L2 cache
• Up to 533MHz frontside bus
• 1.0GB of PC2-5300 DDR2 SDRAM memory (2 x 512MB)
• 160GB 5400-rpm Serial ATA (SATA) hard drive
• Multiformat DVD drive with Double Layer support (reads/writes DVD±R/RW, DVD-RAM, DVD±R Double Layer, CD-R/RW)
• Intel Pro/Wireless 3945ABG (802.11a/b/g) wireless LAN
• 10/100Base-T Ethernet LAN port
• 56K V.92 fax/modem
• 4 USB 2.0 ports
• 1 FireWire (IEEE 1394) port
• 1 S-video out port
• 4-in-1 memory card reader (reads SD, MMC, Memory Stick, Memory Stick Pro)
• PC Card slot: supports Type I or Type II
• Intel Graphics Media Accelerator 950 with up to 224MB of shared memory
• High Definition Audio (2-channel) with built-in speakers, microphone jack and headphone/audio-out jack
• 6-cell lithium-ion battery (2400mAh)
• Dimensions: 1 2/5"H x 14 1/10"W x 10 2/5"D
• Case made of aircraft-grade aluminum with high-impact composite finish
• Weight: 6.4 lbs
#4
• HP DV9410US Notebook PC
Specs
Microsoft Windows® Vista Premium
Processor AMD Turion 64 X2 Dual-Core Mobile Technology TL-56
Memory (RAM) 1024MB DDR2 System Memory (2 Dimm)
Memory Expandable to 2GB
Hard Drive 160GB (5400RPM) Hard Drive
Optical Drive LightScribe Super Multi 8X DVDñR/RW with Double Layer Support
Display 17.0" WXGA+ High-Definition BrightView Widescreen Display
Operating System Microsoft Windowsr Vista Premium
Battery Type Lithium ion 2.5hrs
Network Card Integrated 10/100BASE-T Ethernet LAN(i) (RJ-45 connector)
Other ports 5-in-1 integrated Digital Media Reader
Video Graphics NVIDIA GeForce Go 6150 (UMA) (e) with up to 287MB
Dimensions 15.16 (L) x 11.65" (W) x 1.57" (H)
Warranty 1-year Limited Warranty
#5 (this is the one I am leaning toward)
Toshiba Satellite A205-S4577******
Processor
Processor Type * : Core™2 Duo Processor Number * : T5300 Processor Speed * : 1.73GHz
Operating System **
Genuine Windows Vista™ Home Premium (32-bit)
Memory Size *
1024MB
Memory Speed
PC2-5300 DDR2 667MHz SDRAM
Display Size *
15.4" widescreen
Display Type *
Widescreen XGA with TruBrite® Technology
Display Resolution *
1280x800
Graphics Engine *
Graphics Memory *
8MB-256MB dynamically allocated shared graphics memory
Hard Drive Size *
160GB
Hard Drive Speed
5400rpm
Optical Drives *
DVD-SuperMulti drive (+/-R double layer) supporting up to 11 fomats
#6
Satellite A215-S4697 notebook includes: 15.4"-diagonal widescreen WXGA (1280 x 800) TruBrite LCD screen
* AMD Turion 64 X2 Dual-Core Mobile Technology TL-52 operating at 1.6GHz
* 2 x 512KB L2 cache
* 1600MHz frontside bus
* 1.0GB of DDR2 SDRAM memory, upgradable to 4.0GB
* 160GB 5400-rpm Serial ATA (SATA) hard drive
* DVD SuperMulti drive with Double Layer support (reads/writes DVD±R/RW, DVD-RAM, DVD±R Double Layer, CD-R/RW)
* Atheros® 802.11b/g wireless LAN
* 10/100Base-T Ethernet network interface
* 56K V.92 modem
* 4 USB 2.0 ports
* 1 FireWire (IEEE 1394) port
* 1 S-video out port
* ExpressCard/54 expansion slot, also supports ExpressCard/34
* 5-in-1 memory card reader: reads SD, MMC, xD, Memory Stick and Memory Stick Pro
* ATI Radeon X1200 graphics with from 128MB to 319MB of shared memory, dynamically allocated
* Windows-compatible audio; built-in stereo speakers; headphone output jack and microphone input jack
* Rechargeable lithium-ion battery (4000 mAh)
* Dimensions: 1 9/16"H x 14 3/10"W x 10 3/5"D
* Weight: 6.3 lbs
#7
Toshiba Satellite Satellite A135-S4727 notebook includes: 15.4"-diagonal widescreen WXGA (1280 x 800) TruBrite LCD screen
# Intel Pentium dual-core processor T2080 operating at 1.73GHz
# 1MB L2 cache
# 533MHz frontside bus
# 2.0GB of PC2-5300 DDR2 SDRAM memory, upgradable to 2.0GB
# 160GB 5400-rpm Serial ATA (SATA) hard drive
# DVD SuperMulti drive with Double Layer support (reads/writes DVD±R/RW, DVD-RAM, DVD±R Double Layer, CD-R/RW)
# Atheros® 802.11b/g wireless LAN
# 10/100Base-T Ethernet LAN port
# 56K V.92 software modem
# 4 USB 2.0 ports
# 1 FireWire (IEEE 1394) port
# 1 S-video out port
# 5-in-1 memory card reader (reads SD, MMC, Memory Stick, Memory Stick Pro, xD-Picture Card
# 1 PC Card slot: supports Type I/Type II PC Card, PCMCIA
# Intel Graphics Media Accelerator 950 with from 8MB to 256MB of shared memory (dynamically allocated)
# Windows-compatible audio with built-in stereo speakers; headphone output jack and microphone input jack
# Rechargeable lithium-ion battery (4000 mAh)
# Dimensions: 1 1/2"H x 14 1/5"W x 10 1/2"D
# Weight: 6.0 lbs
Take a look at Clevo notebooks also going by the name Sager in the US. They have several nice laptop gamers including a sli model that uses desktop processors. This forum pages list many of their models as well as suppliers/costume sellers for the Clevo notebooks. In general these are faster, cheeper, and more custumizable than any standard seller. Clevos have been used as the barebones for companies Like Voodoo and Alienware for years and just beem rebadged. So they make a nice system.
http://forum.notebookreview.com/showthread.php?t=91510
Come on guys. Only one reply so far. I figured I would have a few more then that. I know that someone out there has something to input on this subject.
