- Jan 5, 2010
- Manchester, UK
Hi all.
I'm after a bit of a pointer really, i have a Laptop that got a glass of water poured into it by a muppet i work with. I have been playing with it in an attempted to see if i could get it working again.
Ok so the starting point of the laptop after it was properly dried by me, i put a good battery on it but it showed no signs of life. It also had a Damaged Keyboard as the guy in question melted the keys with a hot air gun
So bit of messing later decided the Mobo was beyond redemption so i got another that was second hand but had been tested, fitted it and now the light comes on when its on charge and if i turn it on the "On" light comes on and the cpu fan starts up but no screen and no hard drive movement etc. I thought the screen may be bad so i plugged it into a Monitor and there was still no picture.
I don't know if it makes any difference but the new Mobo CDRW port is a Sata rather than an IDE so i don't have a Disk drive in it at the moment.
Does anyone have any ideas what to look at next? TBH i'm just playing with it for fun but it would be nice to get it going.
