Supposedly you only need the OS there so that the upgrade can be done, no need to activate or anything, as soon as windows 7 is installed you can just run Win 8 upgrade. Some people advise after that to backup the fresh Win 8 install somewhere, wipe the drive, and then use the backup to have a "clean install" - that is, as close to a clean install as you can get with an upgrade.
