Hi I'm very new to overclocking & I would like some help from you experienced overclockers. Thanks in advance.
My spec is:
CPU e6850 with Noctua NH-D14 cooler
Mobo Gigabyte GA-p35-ds4
RAM Kingston DDR2-1066MHz 4GB
5-5-5-15 voltage 2.2v
Display 8800GTX
Power CoolerMaster 650W
OS XP Home SP2 (32-bit)
My system runs well upto 3.66 GHz. The OCCT test gives CPU temp of 58-63 degrees C (room temp is 32 degrees) & 1.34-1.36 vCore. When I try 3.70 GHz or above, the screen just go blank & the system reboot. The BIOS settings at this time is:
CPU Enhanced Halt (C1E) disabled
CPU EIST Function disabled
Robust Graphics Booster Auto
CPU Clock Ratio 9x
CPU Freq 3.70 GHz(412x9)
CPU Host Clock Control enabled
CPU Host Freq 412 MHz
PCI Express Freq 100 MHz
CIA2 disabled
System Memory Multiplier (SPD) 2.00
Memory Freq (MHz) 800 824
System Voltage Control Manual
DDR2 Overvoltage Control Normal
PCI-E Overvoltage Control Normal
FSB Overvoltage Control Normal
(G)MCH Overvoltage Control Normal
Loadline Calibration Auto
CPU Votage Control 1.4000v
Normal CPU vCore 1.3125v
So did I miss anything in the BIOS settings, do I have to change the voltage of the RAM? My target is to overclock to 3.80 GHz. Many thanks.
Stephen
My spec is:
Display 8800GTX
CPU Clock Ratio 9x
CIA2 disabled
Stephen
